Built-In Functions |
Working Current | Static current: 200mA (@25V) Dynamic current: 400mA (@25V) Locked-rotor current: 4A (@25V) |
Operating Temperature | -10°C ~ 50°C |
Weight | 1.26Kg |
Dimensions | 233mmX210mmX192mm |
GCU Weight | 63g |
GCU Dimensions | 64.2 mm ×34.1mm ×19.5mm |
Supported Camera | Panasonic GH4/GH3 |
Supported Lens Currently | OLYMPUS M.ZUIKO DIGITAL ED 12mm f2.0 |
GCU Input Power | 4S~12S LiPo (Recommend 6S if used with the S800 EVO or S1000) |
Control Requirement | Minimum of four spare receiver channels |
Assistant Software System Requirement | Windows XP SP3; Windows 7; Windows 8 (32 or 64 bit) |
Load Weight (Reference Value) | 690g(@Panasonic GH4 with OLYMPUS M.ZUIKO DIGITAL ED 12mm f2.0, Battery and SD Card) |
Controlled Angle Accuracy | ±0.01° |
Maximum Controlled Rotation Speed | Pan axis: ±130°/s Tilt axis: ±130°/s Roll axis: ±30°/s |
Rotation | Pan axis control: ±360° continuous rotation Tilt axis control: +50°/-140° Roll axis control: ±40° |
Keep your camera level however you fly
