Zenmuse Z15-BMPCC
Cinema grade aerial video
Zenmuse Z15-BMPCC
General
Built-In Functions
  • Three Working Modes
    · Orientation-locked control
    · Non orientation-locked control
    · FPV mode (Reset)
  • Built-in independent IMU module
  • DJI gimbal special servos drive module
  • HDMI-AV/HD module
  • Wireless video transmission supported
  • Camera record control supported
  • Wide range voltage input supported
  • S-Bus/PPM Receiver supported
Mechanical & Electrical Characteristics
Working CurrentStatic current: 200mA (@25V)
Dynamic current: 400mA (@25V)
Locked-rotor current: 1.8A (@25V)
Operating Temperature-10°C ~ 50°C
Weight1.26Kg
Dimensions227mm(H) × 212mm(D) × 210mm(W)
GCU Weight63g
GCU Dimensions64.2 mm ×34.1mm ×19.5mm
Peripheral
Supported CameraBMPCC
Current Supported LensOLYMPUS M.ZUIKO DIGITAL ED 12mm f/2.0
GCU Input Power4S~12S LiPo (Recommend 6S if used with the S800 EVO/S1000)
Control RequirementMinimum of four spare receiver channels
Assistant Software System RequirementWindows XP SP3; Windows 7; Windows 8 (32 or 64 bit)
Working Performance
Load Weight (Reference Value)487g(@BMPCC with OLYMPUS M.ZUIKO DIGITAL ED 12mm f2.0, Battery and SD-Card)
Controlled Angle Accuracy±0.01°
Maximum Controlled Rotation SpeedPan axis: ±130°/s
Tilt axis: ±130°/s
Roll axis: ±30°/s
Controlled Rotation RangePan axis control: ±360° continuous rotation
Tilt axis control: +50°/-140°
Roll axis control: ±40
DJI - Zenmuse Z15 BMPCC Installation Demonstration
2014-05-09
Connecting the DJI Lightbridge and Zenmuse Z15-BMPCC
2014-05-13
Winter in Austria
Winter in Austria
2014-05-15
Documents & Manuals
  • Zenmuse Z15-BMPCC Release Notes
    2016-01-14
  • Zenmuse Z15-BMPCC User Manual v1.4
    2015-09-28
Software & Drivers
  • Zenmuse Assistant Software v1.4 (Stop distributing and updating)
    2015-01-04
  • DJI WIN Driver Installer
    2013-01-18
  • * Important Note:
    As DJI Innovations has no control over use, setup, final assembly, modification (including use of non-specified DJI parts or misuse, no liability shall be assumed nor accepted for any resulting damage or injury. By the act of use, setup or assembly, the user accepts all resulting liability.
    We will stop distributing and updating "Zenmuse Assistant Software v1.4" on May 15, 2018, including adaptations to the new version of the operating system. After May 15, 2018, the software is still available for download. The server shutdown time will be announced separately. Looking ahead, DJI will continue to provide the best tools and services for users and developers.
BUY Zenmuse Z15-BMPCC
Keep your camera level however you fly.
We Value Your Privacy
We use cookies to personalize and enhance your browsing experience on our websites. You can manage your settings at any time through Cookie Preferences or read our Cookie Policy to learn more.
Cookie Preferences
Cookies are small files which, when placed on your device, enable us to provide certain features and functionality of DJI websites and online services to you. We use the following types of cookies on our websites. View Cookie Policy for full details.
