Specs
General
  • Model
  • IN2BS
  • Dimensions
  • 484 mm × 226.5 mm × 220 mm
  • Net Weight
  • 7.7 kg
  • Max Internal Load
  • 12 kg
  • Compatible Stored Items
  • TB50 Intelligent Battery × 12WB37-4920mAh-7.6V Intelligent Battery × 2WCH2 Charging Hub × 1AC Power Cable × 1
  • Input
  • 100-240 V, 50-60 Hz
  • Output
  • Battery Port: 26.1 V max., 6.75 A max. × 8Remote Controller Port: 26.1 V max., 4 A max. × 2USB Port: 5 V, 2 A × 2
  • Operating Temperature
  • 41° to 104° F (5° to 40° C)
  • Charging Time*
  • TB50 Intelligent Battery:90 minutes (Normal mode); 35 minutes (Quick mode);4 hrs 20 minutes (Silent mode)Remote Controller:2 hrs 24 minutes (GL6D10A); 3 hrs (GL800A)* Charging times are tested in a lab environment at room temperature. This values should be used forreference only.
