SENSOR
Size1/2.3"
TypeCMOS
Effective Pixels12.4M
ISO Range100~3200
MAX-PIXELS
Max-Pixels12.4M
Burst ShootingFull pixels 7fps
Shutter Speed8~1/8000 sec
EV Range-3~+3, 1/3
AEBSupport
IntervalSupport
Time LapsedSupport, 5/7/10/20/30 sec
DNGSupport
MISC.
ExposureP/S/M
AE MeteringAuto/spot metering
AE LockSupport
WBauto/default/manual
Focus ModeFocus at ∞
Focus ModeN/A
AF AUXN/A
AE LockN/A
Focus PeakingN/A
ZebraSupport
AdjustmentSupport
StylesRGB,Color looks, LOG
EnhancementHDR Photo
SoftwareN/A
LENS
Optics20mm (35mm format equivalent)f/2.8 focus at ∞
IrisF/2.8
Diagonal FOV94 degree
Equivalent20mm
Distortion0.90%
Focus RangeInfinite
Auto-FocusN/A
VIDEO
Resolution4096x2160(25/24P)
3840x2160(30/25P)
1920x1080(60/50/48/30/25/24P)
1280x720(60/50/48/30/25/24P)
EncoderMPEG4/AVC/H.264
Max-Bitrate60Mbps@4096x2160(25/24P)
60Mbps@3840x2160(30/25P)
45Mbps@1920x1080(60/50/48/30/25/24P)
15Mbps@1280x720(60/50/48/30/25/24P)
FormatMP4/MOV
StorageMicro-SD Class 10
Video NRSupport
StabilizerSupport
Tutorials
DJI Inspire 1 - Unboxing and Preparing for Safe Flight
2015-02-17
DJI Inspire 1 Tutorial "Go App"
2015-01-15
DJI Inspire 1 Unboxing
2015-01-12
Showcase
DJI Inspire 1 – “Soar”
2014-11-12
Introducing the Inspire 1
2014-11-12
DJI Inspire 1 – “Vintage”
2014-11-12
Firmware
  • Inspire 1 Firmware v1.10.1.40
    2016-12-15
  • Inspire 1 Firmware v1.9.1.30
    2016-07-07
  • How to Update Firmware v1.4
    2015-10-22
  • Inspire 1 Firmware v1.3.0.00
    2015-08-04
Software & Drivers
  • Inspire 1/ Phantom 3/ X5 LOG mode Transcoding Tool v1.0.0
    2015-12-07
  • Inspire 1/ Phantom 3/ X5 LOG mode Transcoding Tool v0.9.2
    2015-10-20
  • DJI DNG Cleaner v1.1
    2015-04-10
  • Charging Hub Upgrader v1.1
    2015-09-09
  • Inspire 1/Phantom 3/ X5 Transcoding Tool v0.9.2
    2015-10-20
    2015-04-10
Documents & Manuals
  • Inspire 1 Release Notes
    2017-07-10
  • Inspire Series Remote Controller Release Notes
    2016-07-28
  • Inspire 1 Safety Guidelines and Disclaimer
    2015-11-18
  • Inspire 1 Quick Start Guide (EN) v2.2
    2016-06-01
  • Inspire 1 Quick Start Guide (DE) v2.0
    2015-12-18
  • Inspire 1 Quick Start Guide (FR) v2.0
    2015-12-18
  • Inspire 1 User Manual (EN) v2.0
    2016-07-19
  • Inspire 1 User Manual (DE) v1.0
    2015-03-20
  • Inspire 1 User Manual (FR) v1.0
    2015-03-19
  • Inspire 1 Safety Guidelines v1.0
    2014-12-31
  • Intelligent Flight Battery Safety Guidelines v1.4
    2016-01-04
  • Charging Hub for Inspire 1 Intelligent Flight Batteries v1.0
    2015-09-01
  • Inspire 1 1345s Quick-Release Propellers Quick Start Guide
    2015-03-26
  • 1345 Propeller Locks Quick Start Guide
    2015-01-23
  • Inspire 1 Maintenance Manual v1.0
    2015-02-28
  • Inspire 1 In the Box
    2014-12-31
  • Inspire 1 Car Charger User Manual
    2016-06-17
  • * Disclaimer of Warranties:
The Inspire 1’s camera has only a very minimal “fisheye” effect, especially when compared to other flying platforms. Dedicated lens profiles for Adobe products such as Photoshop or After Effects will be released soon. Note: The focal length of the Inspire 1 lens is equivalent to 20mm.
Yes. Just press and hold your finger on the Camera page of the GO app for a few seconds. A circle will appear, which can then be dragged to adjust the orientation of the camera.
4K video generates 450MB per minute. At this rate, a 16GB SD card can hold up to 36 minutes of footage.
In your DJI Pilot app, check whether you are recording in PAL or NTSC format and confirm that it matches the format that is used by your display device. NTSC (60 Hz) is standard in the United States and Japan. PAL (50 Hz) is commonly used in EU countries and in China. Your video may appear blurry if it is not formatted correctly for the display device you are using.
This is completely normal. The cooling fan is built in to protect critical sensors, ensuring that normal temperatures are maintained and the camera can function properly. When the sensor temperature exceeds 30 ℃, the fan is automatically activated. The fan is turned off when the temperature drops below 20 ℃.
Buy Zenmuse X3
Creativity Unleashed
