Osmo Action 4
Osmo Action 4
Set the Tone
Buy Osmo Action 4 at the DJI Store to enjoy DJI expert help, one-on-one exclusive customer service, professional technical support, express shipping, 1% DJI Credit back on your purchase, and more.
    Product Highlights
    Imaging System
    Usage Scenarios
    Intelligent Modes
    Comprehensive Accessories
Ignite the Action
Capture the raw exhilaration of any moment with striking image quality and unmatched flexibility, even when the lights dim. Osmo Action 4 empowers thrill-seekers to record it all, share the rush, and set the tone.
1/1.3″ Image Sensor
Unleash the power of every pixel when you record with Action 4. A wide f/2.8 aperture and 2.4μm-equivalent pixel size deliver shots loaded with detail from sunup to sundown and beyond.
10-bit D-Log M Color Performance
10-bit D-Log M [3] color mode gives you over one billion colors and a wider dynamic range to play with in post.
4K/120fps
The best moves deserve buttery slo-mo. That's why Action 4 has 4K UHD 120fps, [4] giving you an easy option to warp time and savor it all.
155° Ultra-Wide Angle
Experience an ultra-wide FOV that pulls you in headfirst with a perspective close to what the human eye sees.
84°
Situational Stabilization
360º HorizonSteady
RockSteady 3.0
360º HorizonSteady goes well past simple action camera stabilization, correcting horizontal tilts at any angle no matter how many flips, twists, or turns go down.
Planning something slightly less extreme? Try HorizonBalancing for horizontal tilt correction up to ±45º.
Adios, camera shake. RockSteady 3.0 injects fluid stabilization into your POV footage, even when shooting 4K/120fps.
Color Temperature Calibration
An advanced color temperature sensor ensures true-to-life tones outdoors, indoors, and underwater for colors that pop straight out of the camera.
Vivid Underwater
DJI Mimo can now sync visual information from Action 4's color temperature sensor for eye-opening details beneath the waves.
Ready When You Are
Crush Any Limit
Limits were meant to be crushed, and Action 4 is the action camera that lets you do exactly that with countless features that are as powerful as they are intuitive.
Boundless Creativity, Intuitive Control
Native Vertical Shooting
Go vertical with ease and flexibility. The Horizontal-Vertical Protective Frame lets you capture lossless vertical footage in seconds.
Dual Touchscreens
Dual water-stain resistant [5] touchscreens make turning the action camera around for parameter adjustments during selfies, mode switching, or video playback a thing of the past.
action camera with dual touch screens
Custom Modes & Quick Switch Button
Features like SnapShot ensure you never miss the biggest moments. Save frequently used settings to C1-C5 shortcuts and switch between modes on the fly with the Quick Switch button and voice prompts.
Robust Power, Compact Form
18m Waterproof
Dive in with confidence and enjoy easy operation even with wet hands. Action 4 is designed to withstand depths of up to 18 meters without a case. [6]
Ultra-long Battery Life,
Fast-Charge Supported
With over 2.5 hours of use, [7] never miss a beat. When you finally do need to recharge, fast-charging has you covered. In just 18 minutes, charge up to 80%. [8] Power up and get back into action.
Low-Temperature, High Performance
A freeze-resistant battery design lets your creativity thrive, even when things get frosty. Enjoy up to 150 minutes of recording in temps as low as -20°C (-4°F). [9]
Highlight
Mark captivating moments as they happen. Press the quick switch button on the side of the camera or the GPS Bluetooth Remote Controller at any time during recording to mark that instant as a highlight. You can also add markers during playback, ensuring you don't miss any impressive moves. Quickly locate the marked clips on the DJI Mimo app’s editing interface, saving time searching for footage and speeding up editing.
& Sports Track
Capture the whole picture with the GPS Bluetooth Remote Controller. [11] Record and integrate data such as speed, gradient, acceleration, and more for videos that showcase every aspect of awesome.
Elevate the Atmosphere
Expanded Recording Options
From dynamic shots with crystal-clear audio to seamless post-editing capabilities, Action 4 is built for recording the razor's edge of fast-paced sports.
Stereo Recording
Ambient Noise Reduction
DJI OsmoAudio™
Direct Connection for Premium Sound Quality
Action 4 is equipped with three mics for omnidirectional recording with improved audio fidelity. A hidden microphone at the bottom of the action camera, plus the advanced wind noise reduction software, give you clear audio even in windy or fast-moving scenarios.
Osmo Action 4 can now directly connect to a DJI Mic 2/Mic Mini transmitter without a receiver, [11], simplifying your gear and workflow for a more efficient creative process. The DJI OsmoAudio™ connection ecosystem delivers premium audio and enables remote start/stop of video recording and an audio transmission up to 70 meters [12].
* Use headphones for the full experience.
Wi-Fi Livestreaming
Action 4 supports livestreaming using Wi-Fi or your phone's hotspot. Simply choose your preferred platform and resolution and connect with your world.
Use an external power supply to keep your action camera charged on longer streams to ensure an uninterrupted broadcast.
Voice Interaction
Voice Prompt
Voice Control
Short-press the Quick Switch button, and the camera will tell you the current shooting mode. Even if the screens are out of sight, you can still select the desired mode.
Try Voice Control [13] when your hands are occupied. Use different voice commands for a fun and hands-free creative process.
action camera with timecode sync
Timecode Sync
Thanks to Action 4's built-in timecode function, you can synchronize footage from multiple cameras for more efficiency during editing.
LightCut App
AI Editing
The LightCut app automatically recognizes elements in your footage and recommends an ideal shot sequence so you can get a superb 4K UHD video with one tap. Choose from a range of templates and generate expressive content of any experience.
One-Tap Editing
Loaded with Templates
Wireless Connection
LightCut can recognize themes within the footage, edit automatically, and output 4K/60fps videos.
The LightCut app is deeply adapted to the usage scenarios of Action 4. It can automatically select biking, diving, surfing, or skiing/snowboarding clips and intelligently match them with exclusive templates to generate epic clips. Templates for camping, vlogging, travel, and parties are also available.
Connect wirelessly to the Action 4 via Wi-Fi for quick previews and auto-editing without the need for outputting footage from the camera, letting you save space on your smartphone.
Accessories that Amplify
Intuitive and hyper-practical new accessories are available to make any high-octane scenario that much more dynamic.
Extra Accessories
  • Osmo Action GPS Bluetooth Remote Controller
    Wear it on your wrist or mount it to the handlebar to remotely control the start of recording. Record sports data with the built-in GPS and integrate them into your video in the DJI Mimo app to make your work pop.
  • Osmo Action Mini Extension Rod
    Palm-sized in storage. It can extend to four sections. Comfortable to hold for a long time. The built-in tripod on the bottom can keep the device securely in place for stable shooting. Ball-joint design on the top makes angle adjustment more convenient.
  • Osmo Action Mini Handlebar Mount
    Supports a 360° rotating view for multi-angle framing. It is easy to mount, with no tools required. The tube diameter is adjustable, [15] making it suitable for different models.
  • Osmo Action Bite Mount
    Secure the camera without holding it, and take POV footage when surfing or biking. It is made of durable food-grade material [16] for comfortable, safe, and effortless shooting.
  • Osmo Backpack Strap Mount
    Quickly attach the camera to your backpack for POV recording during outdoor activities. It also securely stores the action camera when not in use.
  • Osmo Action Multifunctional Battery Case
    It stores three batteries and two microSD cards. It intelligently fast-charges three batteries and can be used together with those batteries as a power bank to charge other devices like a smartphone.
  • DJI Mic 2
    The wireless mic, DJI Mic 2, boasts high-quality audio recording, intelligent noise canceling, and support for 32-bit float internal recording, making it ideal for capturing rich, detail-filled audio for vlogs, interviews, livestreams, and more.
  • Osmo Action Hanging Neck Mount [17]
    The hanging neck mount uses a unique silica gel material that is comfortable to wear and can reshape freely. Use it to quickly take POV shots during fishing, travel, etc.
  • Osmo Action 360° Wrist Strap
    Wear the camera on the hand or wrist during biking to take immersive POV shots, and adjust the shooting angle immediately.
DJI Mic 2
* All accessories listed in this section are sold separately.
Want to See More? It's All Here
3D
AR
All-around and Comprehensive Look
Click and drag the image to view.
Take a closer look from every angle.
Use your iOS camera to scan the QR code for an AR preview of Osmo Action 4.
Osmo Action Series Product Comparison
Osmo Action 4
Osmo Action 4
Osmo Action 3
Osmo Action 3
DJI Action 2
DJI Action 2
1/1.3-inch CMOS
Sensor
1/1.7-inch CMOS
Sensor
1/1.7-inch CMOS
Sensor
145 g
Weight
145 g
Weight
120 g
Weight
160 minutes [7]
Operating Time
160 minutes [18]
Operating Time
70 min (Camera Unit)
180 min [19] (Camera Unit & Power Module)
Operating Time
18m Waterproof
Caseless Waterproof
16m
Caseless Waterproof
10m
Caseless Waterproof
-20° to 45° C (-4° to 113° F)
Operating Temperature
0° to 40° C (32° to 104° F)
4K/120fps
Max Video Resolution
4K/120fps
4K/120fps
Supports Fast Charge
Quick-Release Design
RockSteady 3.0/3.0+
HorizonSteady
HorizonBalancing
Stabilization System[20]
RockSteady 3.0/3.0+
HorizonSteady
HorizonBalancing
RockSteady 2.0
HorizonSteady
HorizonBalancing
Set the Tone
Osmo Action 4
  • 1/1.3-inch Sensor & Stunning Low-Light Imaging
  • 10-bit & D-Log M Color Performance
  • Deep-Freeze Resistant & Long-Lasting Battery Life
  • Magnetic Quick Release & Native Vertical Video
  • 360° HorizonSteady
USD $299From USD $229
* The Pre-Rec function supports shooting durations of 5/10/15/30/60 seconds.
** The maximum extension length of the Osmo 1.5m Extension Rod is approx. 1.5 meters. Refer to the actual product for the specific value.
1. The Horizontal-Vertical Protective Frame is required for vertical shooting.
2. The 155° FOV supports up to 4K/60fps video recording and requires stabilization to be turned off.
3. 10-bit color depth is available for videos recorded in HEVC codec and the D-Log M color mode.
4. The 120fps high frame rate is applicable to 1080p, 2.7K 16:9, and 4K 16:9 video specifications.
5. The hydrophobicity of the front screen, rear screen, and lens protective cover is realized through AF coating, which may be affected by accidental scratches.
6. Before using the action camera, close the battery cover and the USB-C port cover, and tighten the Glass Lens Cover. It is recommended to install the Waterproof Case for long-term underwater shooting or in environments with high water impact pressure. Osmo Action 4 and its Waterproof Case have an IP68 waterproof rating. Do not use the camera in hot springs or extreme underwater environments, or let it come into contact with corrosive or unknown liquids.
7. In 25° C (77° F) laboratory environment and at 1080p/24fps (16:9), with RockSteady on, Wi-Fi off, and screen off. This data is for reference only. Actual battery life may vary when activating and using Osmo Action 4 in the European Union and UK, due to local regulations regarding operating temperature of the product. Please refer to the actual user experience.
8. Tested in a 25℃ (77°F) laboratory environment while using DJI 30W USB-C Charger with the photo taking/video recording function disabled and screen off, and should be used for reference only.
9. In -20° C (-4° F) laboratory environment and at 1080p/24fps (16:9), with RockSteady on, Wi-Fi off, and screen off. This data is for reference only.
10. InvisiStick supports up to 1920×1440 video when eliminating on the cloud, and up to 1280×960 video when eliminating locally.
11. Sold separately.
12. Measured in an unobstructed environment without interference. In conditions with signal interference or physical barriers, the transmission distance may be shorter. Refer to the actual use experience.
13. Currently only supports Mandarin Chinese and English. Use this function in a quiet environment and make sure that the pronunciation is clear and accurate.
14. The ideal paste temperature range is -10° to 40° C (14° to 104° F). Do not attach to curved surfaces, and make sure the attachment surface is clean. It is recommended to press down on the attachment for 10 seconds after applying and leave for 30 minutes before use.
15. The Osmo Action Mini Handlebar Mount supports round handlebars with a diameter of 8-35 mm.
16. The plastic material of Osmo Action Bite Mount that gets contact with mouth meets FDA test standard.
17. Use caution when participating in certain extreme sports like rock climbing and diving. Ensure that no foreign objects get caught around your neck to avoid the risk of suffocation.
18. Tested in a 25° C (77° F) laboratory environment while recording 1080p/30fps video in normal video mode with Enhanced Image Quality disabled, EIS disabled, and the screens off, and should be used for reference only.
19. The maximum operating time was tested when recording video at 1080p/30fps (Power Reserve mode) with electronic image stabilization disabled and under laboratory conditions.
20. Electronic stabilization (EIS) is not supported in Timelapse and Slow Motion modes. HorizonSteady supports only 1080p/2.7K video (≤60fps) in 16:9 ratio, and HorizonBalancing supports only 1080p/2.7K/4K video (≤60fps) in 16:9 ratio.
We Value Your Privacy
Cookie Preferences
Contact Us
Online Customer Service
Monday - Sunday: 6:00 - 18:00 (PST/PDT)
DJI Store APP
Manage your devices in one place. Conveniently request services.
Check It Out
