Specs
Aircraft
  • Takeoff Weight
  • 248 g
    ‌Standard aircraft weight (including the Intelligent Flight Battery, propellers, and a microSD card). The actual product weight may vary due to differences in batch materials and external factors. Training or examination is not required for flying this product in most countries and regions. Always check local laws and regulations before use. With the Intelligent Flight Battery Plus*, the aircraft will weigh more than 249 g (about 290 g). Always check and strictly abide by local laws and regulations before flying.
  • Dimensions
  • Folded (without propellers): 148×90×62 mm (L×W×H)
    Unfolded (with propellers): 251×362×72 mm (L×W×H)
  • Max Ascent Speed
  • 5 m/s
  • Max Descent Speed
  • 3.5 m/s
  • Max Horizontal Speed
  • 16 m/s
    Measured in a controlled wind tunnel environment under conditions equivalent to windless operation and sea-level altitude, with the aircraft ascending vertically to a height of 1.5 meters above the ground in Sport mode. Actual experience may vary depending on the environment, usage, and firmware version.
  • Max Takeoff Altitude
  • With Intelligent Flight Battery: 4000 m
    With Intelligent Flight Battery Plus*: 3000 m
    Increase in aircraft weight can affect flight propulsion. When the aircraft is using the Intelligent Flight Battery Plus, do not mount additional payloads like a propeller guard or third-party accessories to avoid diminished propulsion.
    * Sold separately and only in selected countries and regions.
  • Max Flight Time
  • 38 minutes (with Intelligent Flight Battery)
    51 minutes (with Intelligent Flight Battery Plus*)
    Measured in a controlled wind tunnel environment under conditions equivalent to windless operation and sea-level altitude, with the aircraft flying forward at a constant speed of 21.6 kph and the camera in Photo mode, until a forced landing due to battery depletion. Actual experience may vary depending on the environment, usage, and firmware version.
  • Max Hovering Time
  • 33 minutes (with Intelligent Flight Battery)
    44 minutes (with Intelligent Flight Battery Plus*)
    Measured in a controlled test environment. Specific test conditions are as follows: hovering in a windless laboratory environment, in photo mode (without photo taking operation during flight), and from 100% battery level until 0%. Results may vary depending on the environment, actual use, and firmware version.
  • Max Flight Distance
  • 18 km (with Intelligent Flight Battery)
    25 km (with Intelligent Flight Battery Plus*)
    Measured in a controlled wind tunnel environment under conditions equivalent to windless operation and sea-level altitude, with the aircraft flying forward at a constant speed of 43.2 kph and the camera in Photo mode, until a forced landing due to battery depletion. Actual experience may vary depending on the environment, usage, and firmware version.
  • Max Wind Speed Resistance
  • 10.7 m/s (Level 5)
  • Max Pitch Angle
  • 40°
  • Operating Temperature
  • -10° to 40° C (14° to 104° F)
  • Global Navigation Satellite System
  • GPS + GLONASS + Galileo
  • Hovering Accuracy Range
  • Vertical:
    ±0.1 m (with vision positioning)
    ±0.5 m (with GNSS positioning)
    Horizontal:
    ±0.3 m (with vision positioning)
    ±1.5 m (with GNSS positioning)
  • Internal Storage
  • N/A
  • Class
  • C0 (EU)
Camera
  • Image Sensor
  • 1/1.3-inch CMOS
    Effective Pixels:48MP
  • Lens
  • FOV: 82.1°
    Format Equivalent: 24 mm
    Aperture: f/1.7
    Focus: 1 m to ∞
  • ISO Range
  • Video:
    100-3200
    Photo:
    100-3200
  • Shutter Speed
  • Electronic Shutter: 2-1/8000 s
  • Max Image Size
  • 8064×6048
  • Still Photography Modes
  • Single Shot: 12 MP
    48 MP: 48 MP
    Timed: 12 MP
    JPEG: 2/3/5/7/10/15/20/30/60 s
    JPEG + RAW: 5/7/10/15/20/30/60 s
    Automatic Exposure Bracketing (AEB): 12 MP, 3 frames at 2/3 EV step
    Panorama: Sphere, 180°, Wide Angle
    HDR: The Single Shot mode supports outputting HDR images.
  • Photo Format
  • JPEG/DNG (RAW)
  • Video Resolution
  • 4K: 3840×2160@24/25/30 fps
    2.7K: 2688×1512@24/25/30/48/50/60 fps
    FHD: 1920×1080@24/25/30/48/50/60 fps
    HDR: Recording with the 24/25/30fps frame rate supports outputting HDR images.
  • Video Format
  • MP4 (H.264)
  • Max Video Bitrate
  • 100 Mbps
  • Supported File System
  • FAT32 (≤ 32 GB)
    exFAT (> 32 GB)
  • Color Mode
  • Normal
  • Digital Zoom
  • 4K: 2×
    2.7K: 3×
    FHD: 4×
  • QuickShots Modes
  • Dronie, Helix, Rocket, Circle, and Boomerang
Gimbal
  • Stabilization
  • 3-axis mechanical gimbal (tilt, roll, and pan)
  • Mechanical Range
  • Tilt: -135° to 80°
    Roll: -135° to 45°
    Pan: -30° to 30°
  • Controllable Range
  • Tilt: -90° to 60°
    Roll: -90° or 0°
  • Max Control Speed (tilt)
  • 100°/s
  • Angular Vibration Range
  • ±0.01°
Sensing
  • Sensing Type
  • Downward vision system
  • Downward
  • Precise Hovering Range:
    0.5-10 m
  • Operating Environment
  • Downward:
    Diffuse reflective surfaces with a clear pattern and reflectivity > 20% (such as walls, trees, or people)
    Adequate lighting (lux > 15, normal indoor lighting conditions)
Video Transmission
  • Video Transmission System
  • DJI O2
  • Live View Quality
  • Remote Controller:
    720p/30fps
  • Operating Frequency
  • 2.400-2.4835 GHz
    5.725-5.850 GHz
  • Transmission Power (EIRP)
  • 2.400-2.4835 GHz:
    < 26 dBm (FCC)
    < 20 dBm (CE/SRRC/MIC)
    5.725-5.850 GHz:
    < 26 dBm (FCC/SRRC)
    < 14 dBm (CE)
  • Max Transmission Distance (free of interference)
  • FCC: 10 km
    CE: 6 km
    SRRC: 6 km
    MIC: 6 km
    Measured in an unobstructed outdoor environment free of interference. The above data shows the farthest communication range for one-way, non-return flights under each standard. During your flight, please pay attention to RTH reminders in the DJI Fly app.
  • Max Transmission Distance (with interference)
  • Strong Interference: urban landscape, approx. 1.5-3 km
    Medium Interference: suburban landscape, approx. 3-6 km
    Low Interference: suburb/seaside, approx. 6-10 km
    Data tested under FCC standard in unobstructed environments with typical interference. Used for reference purposes only and provides no guarantee for actual flight distance.
  • Max Download Speed
  • DJI O2:
    5.5 MB/s (with DJI RC-N1 Remote Controller)
    5.5 MB/s (with DJI RC)
    Wi-Fi 5: 25 MB/s*
    * Measured in a laboratory environment with little interference in countries/regions that support both 2.4 GHz and 5.8 GHz, with footage saved to the SD card. Download speeds may vary depending on the actual conditions.
  • Lowest Latency
  • Approx. 200 ms
    Depending on the actual environment and mobile device.
  • Antenna
  • 2 antennas, 1T2R
Battery
  • Capacity
  • Intelligent Flight Battery: 2453 mAh
    Intelligent Flight Battery Plus*: 3850 mAh
  • Weight
  • Intelligent Flight Battery: Approx. 80.5 g
    Intelligent Flight Battery Plus*: Approx. 121 g
  • Nominal Voltage
  • 7.38 V
  • Max Charging Voltage
  • 8.5 V
  • Type
  • Li-ion
  • Energy
  • Intelligent Flight Battery: 18.1 Wh
    Intelligent Flight Battery Plus*: 28.4 Wh
  • Charging Temperature
  • 5° to 40° C (41° to 104° F)
  • Charging Time
    64 minutes (with the DJI 30W USB-C Charger and the battery mounted to the aircraft)
    56 minutes (with the DJI 30W USB-C Charger and the battery inserted into the Two-Way Charging Hub)
    101 minutes (with the DJI 30W USB-C Charger and the battery mounted to the aircraft)
    78 minutes (with the DJI 30W USB-C Charger and the battery inserted into the Two-Way Charging Hub)
Charger
  • Recommended Charger
  • DJI 30W USB-C Charger or other USB Power Delivery chargers (30 W)*
    * When you charge the battery mounted to the aircraft or inserted into the Two-Way Charging Hub, the maximum charging power supported is 30 W.
Charging Hub
  • Input
  • 5 V, 3 A
    9 V, 3 A
    12 V, 3 A
  • Output
  • USB-A: Max Voltage: 5 V; Max Current: 2 A
  • Charging Type
  • Three batteries charged in sequence
  • Compatible Batteries
  • DJI Mini 3 Pro Intelligent Flight Battery, DJI Mini 3 Pro Intelligent Flight Battery Plus*
Storage
  • Recommended microSD Cards
  • SanDisk Extreme 32GB V30 A1 microSDXC
    SanDisk Extreme 64GB V30 A1 microSDXC
    SanDisk Extreme 128GB V30 A2 microSDXC
    SanDisk Extreme 256GB V30 A2 microSDXC
    SanDisk Extreme Pro 32GB V30 A1 microSDXC
    Kingston Canvas Go!Plus 64GB V30 A2 microSDXC
    Kingston Canvas Go!Plus 128GB V30 A2 microSDXC
    Kingston Canvas Go!Plus 256GB V30 A2 microSDXC
    Kingston Canvas React Plus 64GB V30 A1 microSDXC
    Kingston Canvas React Plus 128GB V30 A1 microSDXC
    Samsung PRO Plus 256GB V30 A2 microSDXC
Remote Controller
  • Max Operating Time
  • DJI RC-N1 Remote Controller
    Without charging any mobile device: 6 hours
    When charging a mobile device: 4 hours
  • Max Supported Mobile Device Size
    180×86×10 mm (L×W×H)
    2.400-2.4835 GHz:
    < 26 dBm (FCC)
    5.725-5.850 GHz:
    < 26 dBm (FCC)
    < 23 dBm (SRRC)
    < 14 dBm (CE)
Others
  • Guaranteed software updates until
  • 2026/12/31
