See the Bigger Picture
Our dream has always been to make a drone that exists where engineering, technology, and the needs of the aerial photographer converge. A drone that embodies all of DJI's advanced, signature technologies, and is able to redefine what is possible for the world of aerial photography.
In creating the Mavic 2, we have made this dream come true.
Mavic 2 Pro & Mavic 2 Zoom
Mavic 2 Pro Camera
Sensor1” CMOS
Effective Pixels: 20 million
LensFOV: about 77°
35 mm Format Equivalent: 28 mm
Aperture: f/2.8–f/11
Shooting Range: 1 m to ∞
ISO RangeVideo:
100-6400
Photo:
100-3200 (auto)
100-12800 (manual)
Shutter SpeedElectronic Shutter: 8–1/8000s
Still Image Size5472×3648
Burst shooting: 3/5 frames
Interval (JPEG: 2/3/5/7/10/15/20/30/60s RAW:5/7/10/15/20/30/60s)
Video Resolution4K: 3840×2160 24/25/30p
2.7K: 2688x1512 24/25/30/48/50/60p
FHD: 1920×1080 24/25/30/48/50/60/120p
Max Video Bitrate100Mbps
Color ModeDlog-M (10bit), support HDR video (HLG 10bit)
Supported File SystemFAT32 (≤ 32 GB)
exFAT (> 32 GB)
Photo FormatJPEG / DNG (RAW)
Video FormatMP4 / MOV (MPEG-4 AVC/H.264, HEVC/H.265)
Aircraft
Takeoff WeightMavic 2 Pro: 907 g
Mavic 2 Zoom: 905g
DimensionsFolded:
214×91×84 mm (length×width×height)
Unfolded:
322×242×84 mm (length×width×height)
Diagonal Distance354 mm
Max Ascent Speed5 m/s (S-mode)
4 m/s (P-mode)
Max Descent Speed3 m/s (S-mode)
3 m/s (P-mode)
Max Speed (near sea level, no wind)72 kph (S-mode)
Maximum Takeoff Altitude6000 m
Max Flight Time (no wind)31 minutes (at a consistent 25 kph)
Max Hovering Time (no wind)29 minutes
Max Flight Distance (no wind)18 km (at a consistent 50 kph)
Max Wind Speed Resistance29–38 kph
Max Pitch Angle35° (S-mode, with remote controller) 25° (P-mode)
Max Angular Velocity200°/s
Operating Temperature Range-10°C to 40°C
5.725 - 5.850 GHz
Transmission Power (EIRP)2.400 - 2.483 GHz
FCC:≤26 dBm
CE:≤20 dBm
SRRC:≤20 dBm
MIC:≤20 dBm
5.725-5.850 GHz
FCC:≤26 dBm
CE:≤14 dBm
SRRC:≤26 dBm
GNSSGPS+GLONASS
Hovering Accuracy RangeVertical:
± 0.1 m (when vision positioning is active)
± 0.5 m (with GPS positioning)
Horizontal:
± 0.3 m (when vision positioning is active)
± 1.5 m (with GPS positioning)
Internal Storage8 GB
Sensing System
Sensing SystemOmnidirectional Obstacle Sensing1
ForwardPrecision Measurement Range: 0.5 - 20 m
Detectable Range: 20 - 40 m
Effective Sensing Speed: ≤ 14m/s
FOV: Horizontal: 40°, Vertical: 70°
BackwardPrecision Measurement Range: 0.5 - 16 m
Detectable Range: 16 - 32 m
Effective Sensing Speed: ≤ 12m/s
FOV: Horizontal: 60°, Vertical: 77°
UpwardPrecision Measurement Range: 0.1 - 8 m
DownwardPrecision Measurement Range: 0.5 - 11 m
Detectable Range: 11 - 22 m
SidesPrecision Measurement Range: 0.5 - 10 m
Effective Sensing Speed: ≤ 8m/s
FOV: Horizontal: 80°, Vertical: 65°
Operating EnvironmentForward, Backward and Sides:
Surface with clear pattern and adequate lighting (lux > 15)
Upward:
Detects diffuse reflective surfaces (>20%) (walls, trees, people, etc.)
Downward:
Charger
Input100-240 V, 50/60 Hz, 1.8A
OutputMain: 17.6 V ⎓ 3.41 A
or 17.0 V ⎓ 3.53 A USB: 5 V⎓2 A
Voltage17.6 ± 0.1 V
Rated Power60 W
APP
Video Transmission SystemOcuSync 2.0
NameDJI GO 4
Live View QualityRemote Controller:
720p@30fps / 1080p@30fps
DJI Goggles:
720p@30fps / 1080p@30fps DJI Goggles RE:
Latency (depending on environmental conditions and mobile device)120 - 130 ms
Max Live View Bitrate12Mbps
Mavic 2 Zoom Camera
Sensor1/2.3" CMOS
Effective Pixels: 12 million
LensFOV: about 83° (24 mm); about 48° (48 mm)
35 mm Format Equivalent: 24-48 mm
Aperture: f/2.8 (24 mm)–f/3.8 (48 mm)
Shooting Range: 0.5 m to ∞
ISO RangeVideo:
100-3200
Photo:
100-1600 (auto)
100-3200 (manual)
Still Image Size4000×3000
Burst shooting: 3/5/7 frames
2.7K: 2688×1512 24/25/30/48/50/60p
Color ModeD-Cinelike
exFAT (> 32 GB)
Gimbal
Mechanical RangeTilt: -135–45° Pan: -100–100°
Controllable RangeTilt: -90–30° Pan: -75–75°
Stabilization3-axis (tilt, roll, pan)
Max Control Speed (tilt)120° /s
Angular Vibration Range±0.01° (Mavic 2 Pro)
±0.005° (Mavic 2 Zoom)
Remote Controller
Operating Frequency2.400 - 2.483 GHz; 5.725 - 5.850 GHz
Max Transmission Distance (unobstructed, free of interference)2.400 - 2.483 GHz; 5.725 - 5.850 GHz
FCC: 10000 m
CE: 6000 m
SRRC: 6000 m
MIC: 6000 m
Operating Temperature Range0℃ - 40℃
FCC: ≤26 dBm
CE: ≤20 dBm
SRRC: ≤20 dBm
MIC: ≤20 dBm
5.725-5.850 GHz
FCC: ≤26 dBm
CE: ≤14 dBm
SRRC: ≤26 dBm
Battery3950 mAh
Operating Current/Voltage1800 mA ⎓ 3.83 V
Supported Mobile Device SizeMax length: 160 mm; max thickness: 6.5–8.5 mm
Supported USB Port TypesLightning, Micro USB (Type-B), USB-C
Intelligent Flight Battery
Capacity3850 mAh
Voltage15.4 V
Max Charging Voltage17.6 V
Battery TypeLiPo 4S
Energy59.29 Wh
Net Weight297 g
Charging Temperature Range5℃ to 40℃
Max Charging Power80 W
Supported SD Cards
Supported SD CardsMicro SD™
Supports a microSD with capacity of up to 128 GB. A UHS-I Speed Grade 3 rating microSD card is required.
Recommended microSD Cards32G
Sandisk V30
Sandisk Extreme V30 Pro
64G
Sandisk Extreme Pro V30
128G
Sandisk Extreme V30
Kingston Canvas Go!
Kingston Canvas React
Footnotes
Footnotes[1] Omnidirectional Obstacle Sensing includes left/right, up/down, and forward/backward obstacle sensing. Sensing for left/right directions is only available in ActiveTrack , POI, QuickShot and Tripod mode. Omnidirectional Obstacle Sensing does not fully cover the circumference of a 360-degree arc. And left and right obstacle sensing system only works in specific modes and environments. DJI warranty does not cover any loss caused by crashing when flying left or right, even when ActiveTrack or Tripod mode is activated. Please be aware of your surroundings and App notifications when operating the Mavic 2 to ensure safety.
These specs have been determined through tests conducted with the latest firmware. Firmware updates can enhance performance, so updating to the latest firmware is highly recommended.
The terms HDMI, HDMI High-Definition Multimedia Interface, HDMI Trade dress and the HDMI Logos are trademarks or registered trademarks of HDMI Licensing Administrator, Inc.
Intro
A Cosmic Voyage with the DJI Mavic 2
2018-08-23
Introducing the DJI Mavic 2
2018-08-23
Tutorials
Mavic 2 Series Tutorial - First Flight
2018-08-23
Mavic 2 Series Tutorial - How to Calibrate the IMU
2018-08-23
How to detach or reattach the Mavic 2’s Gimbal Protector
2018-10-30
Product
The only difference between both editions is their respective gimbal cameras.
The Mavic 2 is an improvement in almost all aspects over the Mavic Pro including camera performance, video transmission, flight time, flight speed, low-noise, omnidirectional obstacle sensing, intelligent functions, and its unique Hyperlapse feature.
Yes. The Mavic 2 is compatible with DJI Goggles (firmware version 01.04.0500 or above) and DJI Goggles RE (firmware version 01.00.0600 or above). Please first activate DJI Goggles or DJI Goggles RE and update their firmware to the latest one on your computer using DJI Assistant 2. Power on DJI Goggles or DJI Goggles RE, choose Linking in Settings, then choose Mavic 2. Press the link button on the Mavic 2 and wait for a few seconds to connect DJI Goggles or DJI Goggles RE to the aircraft. DJI Goggles only support the 2.4 GHz signal frequency, while DJI Goggles RE support 2.4/5.8GHz dual signal frequency for more powerful performance.
* To download the version of DJI Assistant 2 that is compatible with DJI Goggles RE, please visit https://www.dji.com/dji-goggles-re/info#downloads.
* To download the version of DJI Assistant 2 that is compatible with DJI Goggles, please visit: https://www.dji.com/dji-goggles/info#downloads.
No.
Camera
The Mavic 2 Pro comes equipped with the all-new Hasselblad L1D-20c camera. The brand new 1-inch CMOS sensor has an active sensing area four times more effective than the original Mavic Pro. The large sensor also means better performance in low-light environments with a more extensive ISO range, and max ISO lifted from 3200 to 12800.
The Mavic 2 Zoom is all about dynamic perspectives and is powered by a 1/2.3-inch 12-megapixel sensor with up to four-times zoom, including a two-times optical zoom (24-48mm) for more creative aerial photography options.
DJI and Hasselblad have spent the last two years in collaboration making the L1D-20c camera, co-developing attributes such as lens definition, image processing engine, and image effect optimization, to make a Hasselblad quality camera small enough to fit on the new Mavic 2 Pro. The L1D-20c also possesses Hasselblad’s unique Hasselblad Natural Colour Solution (HNCS) technology, helping users to capture gorgeous 20-megapixel aerial shots in stunning color detail.
The Mavic 2 Pro is capable of recording 3840×2160 10-bit 4K Dlog-M and 4K HDR 10-bit videos at 100Mbps.
The Mavic 2 Zoom's 24–48 mm optical zoom camera supports shooting at 4x lossless zoom 1080p video.
No. However, you can control the Mavic 2’s gimbal movements with DJI GO 4 or a connected pair of DJI Goggles. In DJI GO 4, press and drag any point of the app's live view interface to do so. You can also rotate the gimbal left and right to a maximum angle of 75° when using Head Tracking mode on the DJI Goggles series.
The Mavic 2’s gimbal structure is optimized for increased stability, meaning that the camera is unable to rotate the gimbal along the roll axis. However, you can choose Vertical mode in Panorama to achieve a stitched vertical photo.
Dlog-M is only available on the Mavic 2 Pro because the pro version was designed with the needs of professional photographers in mind, meeting demands for greater color correction capabilities.
On the other hand, the Mavic 2 Zoom has D-Cinelike to realize quick and easy color correction. Along with Dlog-M, D-Cinelike reserves more highlight and color information than any normal color correction mode, leaving more room for post-processing.
No.
Full FOV down samples from the 5.5K sensor to 4K resolution while HQ crops in the center for finer image quality but less FOV. Full FOV view is 75° and HQ view is 55°. You can select between them according to your actual shooting demands.
Features
No.
Go to Camera Settings and tap the ‘Save Original’ button. You can select to save the original photos of the Hyperlapse video in either JPEG or RAW format. In ‘Storage Location’ you can choose to keep them on the Micro SD card or the internal storage.
Propulsion
18 km in extreme testing environments measured in 50.4 kph windless conditions down to 0% battery. However, be sure to keep enough battery during flights for a safe return.
The Mavic 2 can resist up to level 5 winds on the Beaufort scale.
No, the sizes are different, and therefore cannot be used on the Mavic Pro Platinum.
The Mavic 2's rotor system is optimized primarily for forward flight. Thanks to its more aerodynamic airframe, the Mavic 2 consumes less power at certain forward flight speeds than when hovering. Therefore, the maximum hovering time is 29 minutes in environments with no wind while the maximum flight time can be up to 31 minutes flying at a constant speed in conditions with no wind.
Omnidirectional Obstacle Sensing includes left/right, up/down, and forward/backward obstacle sensing. Sensing for left/right directions is only available in ActiveTrack, POI, QuickShot and Tripod mode.
Note: Omnidirectional Obstacle Sensing does not fully cover the circumference of a 360-degree arc. And the left and right obstacle sensing system only works in specific modes and environments. DJI warranty does not cover any loss caused by crashing when flying left or right, even when ActiveTrack or Tripod mode is activated. Please be aware of your surroundings and App notifications when operating the Mavic 2 to ensure safety.
Yes. The Mavic 2's default setting has auto LED enabled, which turns the Bottom Auxiliary Light on/off depending on the brightness of your environment. You can disable this feature in the app, and you can also manually turn on/off the Bottom Auxiliary Light in the app.
Remote Controller & Video Transmission
OcuSync 2.0 supports both 2.4 GHz and 5.8 GHz frequency bands, featuring stronger interference resistance and auto-switching capabilities to deliver 10 km 1080p video transmission feeds (unobstructed, free of interference, and when FCC compliant).
120–130 ms, which is 40–50 ms shorter than the first generation.
No.
You can use an ordinary USB cable to connect your smartphone to the remote controller via the USB port at the bottom of the controller (be sure to pull up the cable at the Micro USB port). This might, however, prove to be slightly inconvenient when flying the aircraft. Cables with different connectors come with the aircraft so you can choose the one most appropriate for you.
No. You can only control it using a remote controller.
Mobile phones that are 6.5–8.5 mm thick and no more than 160 mm long will fit in the remote controller clamps comfortably. We strongly recommend you to remove the protective cover before attaching your mobile phone. For tablets beyond this measurement range, please purchase the DJI Mavic 2 Tablet Holder.
Battery
No. The Battery Charging Hub charges batteries in sequence according to their power levels from high to low, avoiding the hassle of interchanging them while charging. Charging in sequence gives you a fully charged battery in the quickest possible way.
Approximately 1.5 hours.
It is recommended to fully charge the batteries at least once every three months.
Updating Firmware
No. If you do, the update will fail. You will then need to download the firmware and update it again.
Yes.
Connect the Mavic 2 to the DJI GO 4 app. The app will then check firmware compatibility automatically. You may upgrade according to the instructions.
No. You need to connect the remote controller with a USB cable and then power on to connect to DJI Assistant 2.
1. Low-battery level.
Before installing an update, make sure the battery level is above 50%.
2. Powering off the Mavic 2 or the remote controller during an update.
If this happens, restart the Mavic 2 and the remote controller, and begin the update again.
3. Internet was disconnected during the firmware download.
If the update failure persists, or the remote controller does not link with the aircraft, there may be firmware inconsistencies between devices. In this case, use DJI Assistant 2 on your computer to update the aircraft and the remote controller to the latest versions separately.
We Value Your Privacy
Cookie Preferences
