DJI Goggles Racing EditioN
Fly Fast. Break Free.
Watch Video
DJI Goggles just got better looking and more powerful, so you can experience FPV racing in style and without traditional restraints. DJI Goggles Racing Edition (RE) feature a redesigned metallic matte black visor and headband, along with padding covered by high-quality red leather. Precisely engineered for racing, DJI Goggles RE are compatible with an OcuSync video transmission module and a high-performance camera module, which work together to transmit digital video signal from up to 7 km away with latency as low as 50 ms,1 in addition to analog signal. Fly with smooth, clear video and experience the thrill of drone racing like never before.
Notes
DJI Goggles RE
Weight (Typical)DJI Goggles RE Body: 502 g;
Headband: 500 g
Dimensions DJI Goggles RE Body: 195 × 155 × 110 mm;
Headband (folded):255 × 205 × 92 mm
Screen Size5-inch × 2
Screen Resolution3840 × 1080 (single screen: 1920 × 1080)
Transmitter Power (EIRP)2.4 GHz:
25.5 dBm (FCC); 18.5 dBm (CE); 19 dBm (SRRC)
5.8 GHz:
25.5 dBm (FCC); 12.5 dBm (CE); 18.5 dBm (SRRC)
Live View Modes1080p30, 720p60, 720p30
Video FormatMP4 (H.264)
Supported Video Play FormatMP4, MOV, MKV
(Video format: H264; Audio format: AAC-LC, AAC-HE, AC-3, DTS, MP3)
Battery Capacity:9440 mAh
Operating Temperature Range32° to 104° F (0° to 40° C)
Charger Input100-240 VAC, 50 / 60 Hz, 0.5 A
Output5 V 3 A / 9V 2A / 12 V 1.5 A
DJI OcuSync Camera
Sensor1/3'' CMOS;
Effective pixels: 1.2M
Lens2.65 mm, f/2.0
Lens Group6G + IR
ShutterGlobal shutter
ISO100 - 3200
FOV148° (D); 111° (H); 79.5° (V)
NotesThe terms HDMI, HDMI High-Definition Multimedia Interface, HDMI Trade dress and the HDMI Logos are trademarks or registered trademarks of HDMI Licensing Administrator, Inc.
DJI OcuSync Air System
WeightAir Unit: 43.7 g;
Camera (cable included): 18.2 g;
Pagoda Antenna: 9.4 g;
Cylindrical Antenna: 9.4 g;
Dipole Antenna: 4.2 g
DimensionsAir Unit: 72 × 33 × 14 mm;
Camera: 29.4 × 28.2 × 22.6 mm
Communication Frequency2.4 GHz / 5.8 GHz
22.5 dBm (FCC); 18.5 dBm (CE); 19 dBm (SRRC)
5.8 GHz:
25.5 dBm (FCC); 12.5 dBm (CE); 25.5 dBm (SRRC)
Live View Modes and Min. Latency960p50: 70 ms; 720p60: 60 ms; 480p50: 50 ms
Max. Transmission Distance 2.4 GHz:7 km (FCC); 4 km (CE); 4 km (SRRC)
5.8 GHz:4 km (FCC); 0.7 km (CE); 4 km (SRRC)
Recommended Frequency Band5.8 GHz; CE: 2.4 GHz; SRRC: 5.8 GHz
Video FormatMP4 (MPEG4)
I/O InterfaceS.Bus, Micro USB, PPM, UART, MMCX, Micro SD card slot
Supported Flight Control SystemsF3, F4, KISS, NAZE
Supported Remote ControllersX9D (Frsky), DEVO 10 (Walkera), T8FG (Futaba),T14SG (Futaba), WTF09sll (WFLY), AT9S (RadioLink)
Input Power9-16.8 V (3S-4S)
Yes. Please first activate DJI Goggles RE and update the firmware to version 01.00.0600 or above on your computer using the appropriate version of DJI Assistant 2. Power on DJI Goggles RE, choose Linking in Settings, then choose Mavic 2. Press the link button on the Mavic 2 and wait for a few seconds to connect DJI Goggles RE to the aircraft.
* To download the version of DJI Assistant 2 that is compatible with DJI Goggles RE, please visit: https://www.dji.com/dji-goggles-re/info#downloads.
1. In addition to the 2.4GHz digital transmission band, the new DJI Goggles RE also supports the 5.8GHz band, which can avoid the usual interference on the more crowded 2.4GHz.
2. DJI Goggles RE has redesigned the internal linear polarized omnidirectional antennas and added new external Pagoda antenna, a 5.8GHz single-frequency omnidirectional left hand circularly polarized (LHCP) antenna.
3. DJI Goggles RE has restructured the radio communication strategy and video decoding algorithm to lower transmission latency to 50 ms* (with wireless transmission latency of less than 10 ms), ensuring smooth and reliable video transmission and avoiding video lag and disconnection from the digital video transmission system when operating in a normal environment.
4. DJI Goggles RE supports analog transmission at any integer frequency between 5.650~5.925 GHz and analog video storage on a Micro SD card.
5. DJI Goggles RE can store digital video on a Micro SD card.
6. DJI Goggles RE supports local video playback and Sphere pano viewing, allowing users to turn their head to get a 360° view of the Sphere pano.
7. The facial pad has been redesigned and the headband has used new replaceable leather materials to make it even more comfortable to wear.
*When tested with a 480p video feed.
1. Latency of the transmission system (end to end ) comes from latency in the camera, coding, wireless transmission, Vsync, display, and screen response.
2. According to testing results, a transmission system with the lowest latency has a latency ranging from 30-50 ms, while the latency of an ordinary transmission system ranges from 50-80 ms.
3. The Ocusync transmission system latency range is 50-70 ms, tested in an environment without interference and with a 480p 50fps video feed, with coding latency measured at approx. 5 ms and wireless transmission latency measured at <10 ms.
DJI Goggles RE supports the 5.8GHz FPV Band A/B/E/F/C (Raceband), up to 40 channels in total. It also receives up to of 275 integer frequencies between 5650~5925 MHz, in which Band C (Raceband) includes 8 channels and the channel interval is 27 MHz. It is recommended to choose Band C when flying multiple aircraft simultaneously.
DJI Goggles RE work with all the DJI drones compatible with the original DJI Goggles, including the Spark, Mavic Pro series, Mavic Air, Mavic 2 series, Phantom 4 Series, and Inspire 2.
In addition to the four antennas built into the original DJI Goggles, DJI Goggles RE are also compatible with external antennas, which work with the built-in ones to support 5.8 GHz video transmission. The external antennas connect to the SMA port on the Goggles' body.
MP4, MOV, MKV
Yes. Supported flight controllers: KISS, F3, F4, and Naze Supported remote controllers: X9D (FrSky), DEVO 10 (Walkera), T8FG (Futaba), T14SG (Futaba), WTF09sll (WFLY), and AT9S (RadioLink)
1. Sphere panos on SkyPixel can be downloaded to an SD card and viewed with Goggles in the Local Storage interface.
2. If Sphere panos are saved to a DJI aircraft, you can download the photos to Goggles RE from Aircraft Storage then view them in the Local Storage interface.
DJI OcuSync Air Unit
Videos recorded by the DJI OcuSync Air Unit will be stored on the SD card inserted into the Air Unit's SD card slot. Videos rendered from the live view will also save to the Goggles' SD card slot. Please note that these SD slots do not support hot swapping.
No.
Yes. However, we strongly recommend you do not use non-DJI antennas as compatibility problems may arise.
3S or 4S batteries.
Connect the video transmission module to a PC with a USB cable. Open DJI Assistant 2 and choose the firmware version you need. Proceed with the firmware update.
No. The metal shell is used for cooling and fixing the device. It should not be removed.
1. Under Auto mode, the DJI OcuSync Air Unit automatically chooses a frequency among 105 channels available in the 5.8GHz frequency band and 63 channels available in the 2.4GHz frequency band.
2. Under Manual mode, the DJI OcuSync Air Unit supports 12 5.8GHz channels and 7 2.4GHz channels. Compared to analog video transmission, these frequency channels were designed to have lower interference between adjacent channels. Where simultaneously working analog video transmission systems can cause severe interference, the OcuSync Air Unit supports up to 19 simultaneously working systems.
DJI OcuSync Camera
No.
No. But you can take screenshot by pressing the touch pad on the Goggles RE with two fingers and hold.
DJI OcuSync Antenna
DJI Goggles RE come with a set of three compatible antennas for different scenarios: • Pagoda: This circularly polarized antenna performs best at 5.8 GHz. • Cylindrical: Also circularly polarized, this antenna operates at 2.4 and 5.8 GHz for fully integrated performance. • Dipole: Linearly polarized, this antenna operates at 2.4 and 5.8 GHz and is lightweight, allowing for a clear video feed at close distances.
Bending the antennas frequently may permanently affect their service life and performance.
It is recommended you do not remove the silicone cover.
No. In many countries, local laws and regulations do not allow unofficial antennas to be used.
We Value Your Privacy
Cookie Preferences
