Download the app to experience DJI Air 3S virtually online.
Download
E1200 Standard
E1200 Standard
TUNED PROPULSION SYSTEM
The E1200 is a fine-tuned propulsion system for multirotors weighing 15-33 pounds (7-15kg). This kit allows you to upgrade or build the flight system of your choice. With enhanced efficiency, safety, and reliability under extreme conditions, the E1200 unlocks greater possibilities for professional aerial photographers and enthusiasts.
The Standard version includes 4216 motors, 40A smart ESCs, and 17-inch ultra-carbon folding propellers. Unlike the highly integrated Pro version, the Standard version’s components are separated, allowing you to work with a much wider range of frames.
E1200 Standard
Max Thrust3900 g/rotor (25 V,Sea Level)
Takeoff Weight Recommended1200 ~ 1400 g/rotor (Sea Level)
Takeoff Weight Max1700 g/rotor (Sea Level)
Battery Recommended6S LiPo
Working Temperature-10°C ~ 60°C
Motor
Stator Size42×16 mm
KV310 rpm/V
Weight205 g
ESC
Max Allowable Voltage26 V
Max Allowable Current (Persistent)40 A
PWM Input Signal Level 3.3 V / 5 V Compatible
Signal Frequency30 Hz ~ 450 Hz
Battery 6S LiPo
Weight (with Cable)72 g
Weight (without Cable)35 g
Propeller
Diameter / Thread Pitch17×6 inch
Documents & Manuals
  • DJI E1200 Standard Tuned Propulsion System User Manual v1.2
    2015-08-06
Software & Drivers
  • DJI ESC Assistant v1.4 (Stop distributing and updating)
    2015-09-29
    2015-10-08
We Value Your Privacy
We use cookies to personalize and enhance your browsing experience on our websites. You can manage your settings at any time through Cookie Preferences or read our Cookie Policy to learn more.
Cookie Preferences
Cookies are small files which, when placed on your device, enable us to provide certain features and functionality of DJI websites and online services to you. We use the following types of cookies on our websites. View Cookie Policy for full details.
Contact Us
Online Customer Service
Monday - Sunday: 6:00 - 18:00 (PST/PDT)
DJI Store APP
Manage your devices in one place. Conveniently request services.
Check It Out
